Nikon Z50 e amenitá connesse
Sintesi di una intervista a Nikon sulla Z50 :
  • In order to reduce the size and weight of Nikon Z50, Nikon use optical Vibration Reduction technology instead of IBIS.
  • Nikon will continue to review consumers needs to release more DX Z-mount lenses.
  • Nikon will run both systems (DSLR & Mirrorless) alongside each other.
  • Nikon is trying to expand the Z users base and will continue to develop products across the whole range (From entry-level models to high-end models). Nikon will also focus closely on mid to high end product development.
  • To make Nikon Z50 more smaller, Nikon don’t use USB Type-C port.
  • Nikon Z 50 is handheld for vlogging. It was the best compromise for the design.
  • Nikon’s strategy is all about giving the best of both worlds, so if users want great DSLRs they can go down that route, or if they want great mirrorless cameras they can go down that route as well. We expect to be investing in DSLR and mirrorless for the future.
  • The standout feature of Nikon Z50 is the sharpness you get from images and high image quality, combined with our EXPEED 6 image processor that’s inherited from the Nikon Z 6. All of this technology, including an excellent low-light performance, in a really small compact body is great to have.
HO CAPITO, allora visto che ha "excellent low-light performance" è giusto metterle davanti un tubo di stufa????
mah
2 ore fa, Prometheus dice:
Sinceramente, cosa ne pensate di questa affermazione? di circostanza? strategia ondivaga o magari si aspettavano un maggiore successo commerciale delle Z per andare a chiudere l'era delle reflex? Che il mercato in continua contrazione abbia fatto venir meno le certezze sul presente e sul futuro? Annunci degli annunci...vedi D6....
Speriamo bene,  e sia chiaro, io tifo con tutto il cuore NIKON!😉
2 ore fa, Valerio Brustia dice:
mah
E questo vale anche per le reflex aps-c. E ti dirò di più: Nikon non è l'unica a ragionare così. Ormai tutte le DX sul mercato hanno ottimi sensori e ottime prestazioni ma, ahimé, nessun produttore realizza lenti adeguate per queste fotocamere. L'unica eccezione (ma solo perchè non costruisce apparecchi FF) è rappresentata da Fiuggi che produce ottiche DX piccole, leggere e di ottima qualità. Purtroppo su Z non esistono le alternative (al momento) rappresentate da Sigma e Tamron.
Primi prezzi trovati on line :
NIKON Z Z50 + NIKKOR Z DX 16-50 VR + SD 64GB 667x Pro Lexar1100,00
NIKON Z Z50 + Z DX 16-50 VR + FTZ + SD 64GB 667x Pro Lexar1250,00
NIKON Z Z50 + Z DX 16-50 + 50-250 VR + SD 64GB 667x Pro Lexar1390,00
24 minuti fa, bimatic dice:
Immagino UE...
E detta così, insieme all FTZ, il 16-50 lo regalano come la scheda sd...
Vedremo NaTIonAL
59 minuti fa, wandanara dice:
Immagino UE...
Vedremo NaTIonAL
...Nital, in arrivo a novembre.
