Ottiche Tamron e Nikon FTZ
Max Aquila
Ottima notizia, un problema in meno da gestire. :)
Di Tamron G2 ne sono stati venduti non pochi a quanto pare.
Precisiamo meglio per gli interessati.
Alcuni obiettivi Tamron hanno manifestato malfunzionamenti in autofocus con il Nikon FTZ sulla Nikon Z.
Tamron si è subito manifestata sisponibile ad intervenire via firmware (il firmware degli ultimi obiettivi Tamron è aggiornabile via attacco USB analogo a quello Sigma).
E questo è l'annuncio della disponibilità dei firmware aggiornati e compatibili (che dovranno essere aggiornati a cura dei proprietari con l'apposita basetta e il programma in dotazione, via PC).
Notice of Firmware Update for Tamron Lens compatibility with Nikon Z7 and FTZ adapter
We would like to announce that new firmware versions are now available for the following three Tamron models. The new F/W versions make the three models compatible with Nikon Z7 and FTZ adapter for general operations. This is an update announcement of our October 4th compatibility notice with some of Tamron Di/Di II series for NIkon mount models not operating properly on Nikon Z7 and Nikon Mount Adapter FTZ.
Applicable models:
The lens firmware can be updated with the separately sold TAP-in Console.
with Nikon Z7 and FTZ adapter [Update Information]
Dear users and potential purchasers of Tamron interchangeable lenses.
Thank you for using Tamron products and for your continuous support.
We would like to announce that new firmware versions are now available for the following three Tamron models. The new F/W versions make the three models compatible with Nikon Z7 and FTZ adapter for general operations(*1).
This is an update announcement of our October 4th compatibility notice with some of Tamron Di/Di II series for Nikon mount models not operating properly on Nikon Z7 and Nikon Mount Adapter FTZ.
(*1) Functions used on DSLR cameras
  1. Applicable models
    SP 15-30mm F/2.8 Di VC USD G2 (Model A041) for Nikon
    SP 24-70mm F/2.8 Di VC USD G2 (Model A032) for Nikon
    18-400mm F/3.5-6.3 Di II VC HLD (Model B028) for Nikon
  2. Announced on Nov. 16 2018
    SP 70-200mm F/2.8 Di VC USD G2 (Model A025) for Nikon
    SP 150-600mm F/5-6.3 Di VC USD G2 (Model A022)  for Nikon
    17-35mm F/2.8-4 Di OSD (Model A037)  for Nikon
    The lens firmware can be updated with the separately sold TAP-in Console.If you do not have a TAP-in Console, please contact your nearest Tamron distributors.
    For a list of Tamron distributors, click here.
Ottimo! :)
Ulteriori aggiornamenti fw delle ottiche Tamron per Nikon reflex da utilizzare tramite adattatore FTZ su Nikon Z7
fonte Fotografi digitali.it:
Tamron ha rilasciato altri tre file per tre ulteriori modelli.
Tamron e Nikon Z7
Come per gli altri modelli aggiornati in precedenza bisognerà procedere all'update tramite la TAP-in Console che però è venduta separatamente. Non sono state rilasciate note particolari per quanto riguarda l'aggiornamento e quindi è stata data "solo" la compatibilità con la nuova mirrorless di fascia alta di Nikon.
Di seguito ricordiamo gli altri tre obiettivi per Nikon Z7 che Tamron ha reso compatibili in precedenza:
  • SP 70-200mm F/2.8 Di VC USD G2 (A025) per Nikon
  • SP 150-600mm F/5-6.3 Di VC USD G2 (A022) per Nikon
  • 17-35mm F/2.8-4 Di OSD (A037) per Nikon
